450r trx kick start headlight mod?
Old Jul 13, 2006 | 01:31 AM
twentycharacters's Avatar
Default 450r trx kick start headlight mod?
ok. be interesting to know what this is.. if you dont already have it, i would suggest getting the extended warranty with this machine. even if you never have to use it- its worth it. they give you 3 or 6 months initially, but you have to get in on the extension before that initial time runs out. parts are high, labor is high. of course, you cant **** in the carb and abuse it or anything, but every part on this bike is high- someone told me the engine alone costs about $3500+!
Old Jul 14, 2006 | 02:48 AM
XterrorX's Avatar
ya i bought the extended warrenty when i got the machine. 3 year service plan, Ya hope this is the only hickup i go through
Old Apr 2, 2007 | 12:27 AM
Quick450r's Avatar
You guys are not that smart. The whole electrical runs off of the motor running. Motor off=no light:motor idle = some light; High rev= extra bright. The motor runs the stator which creates the electricity for the whole bike. when you hit the back brakes its like loading the engine not allowing the motor to pull the stator as fast as you want to allow light. FIX = pull the clutch in rev motor for light or get a bike with a battery. Problem solved.
Old Apr 2, 2007 | 01:28 AM
>>>>>>>>>>>>&g t;>>>>>>>>>>>> >>>>>>>>>>>>&g t;>>>>>>>>>>>> >>>>>>>>>>>>&g t;>>
before you start stuff with an old thread that im sure has been resolved by now, if you actually read what was going on, it wasnt so cut and dry. i (on Wed July 12, 2006) and others did mention the engine rev and light output. I asked about hitting the brake, he said it did it no matter if he pulled the clutch in or hit the brake...BUT your reasoning is slightly flawed; a bike with a battery 99% of the time that battery is running the lights as well and they only get nominally brighter during revs... go to any raptor, warrior, recon, etc with a battery: turn the key on and turn the lights on - they work. now start the engine - hey lights still on and not much brighter. rev it - not much brighter....in this case it did not apply to the 05 450r and that was mentioned as well.
alix
Jun 28, 2015 03:28 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Dabears1983
Jun 16, 2015 12:17 PM
4trax300ex
Jul 29, 2000 11:41 AM
rking85
May 20, 2000 11:01 PM
