06 rubi dont like swimmin
Old Aug 13, 2006 | 01:19 PM
swampdonkey016's Avatar
Default 06 rubi dont like swimmin
ive got a 06 rubicon and everytime i take it in water up to the bottom of the seat the thing dies. last time i checked the air box not a stitch of water and every time i do this i have to drain the carb bowl to get it running again. if anyone else here has had this problem and found out how to fix her drop a line
by the way excellent machine. have 27 inch itp 589s front and back brush guards 2500 warn underground scoop lights front and back(2 back 1 front) only 4 months old and already 2400 kms
Old Aug 13, 2006 | 07:58 PM
HondaMon's Avatar
If water gets in the air box, it's probably sucking it right on through to the carb and not stopping at the filter, I wouldn't get into that much water with my 07, just don't like the idea of water in the engine. If you want to run in deep water, you should put a snorkel on.
Old Aug 13, 2006 | 10:48 PM
goattrotter's Avatar
Two things,
Did you extend your carb vents?
Put a little bottle on the carb over flow so that it causes a air gap" hard to explain"
My rubicon with my mini snorkel and the above is awsome in the water.
http://community.webshots.com/photo/...87869452shNjRv
Old Aug 13, 2006 | 11:00 PM
Rinman's Avatar
Yes, as goattrotter said extend the vent line from your carb. There is a small rubber line coming from the bottom of your carb. Remove it and replace with one that will reach your handle bar area. Move it up as high as possible.
Old Aug 14, 2006 | 04:05 PM
sporter's Avatar
Rinman,
I thought I saw two of those lines coming from the carb??
Old Aug 17, 2006 | 08:58 PM
RancherATCrazy's Avatar
Kick azz pics on that link goattrotter [img]i/expressions/face-icon-small-cool.gif[/img]
Old Aug 18, 2006 | 01:23 PM
Triton54's Avatar
Wouldn't an 06 have efi?, There shouldn't be any carb with a hose on the bottom of it should there?
Oneidgoof
Jun 14, 2001 03:06 PM
bigred250x
Feb 25, 2001 04:45 PM
Swampdonky
Feb 11, 2001 12:29 AM
Swampdonky
Feb 10, 2001 01:29 PM
FireFighter
Jan 7, 2001 04:50 PM
