dumb question about oil change
Old Aug 31, 2006 | 10:48 AM
bamurf80's Avatar
Default dumb question about oil change
I know this is probably a very dumb question but this is the first honda I have ever owned. I am going to change the oil. Where is the filter at on the motor? Also how do you drain the oil from the tank? When filling do you fill the tank all the way full?
it is a 2003 Honda 400ex
Thanks
Bamurf80
Old Aug 31, 2006 | 10:59 AM
ridinhondared's Avatar
the filter cover is on your right-hand side down by the brake pedal, it will have 2 8mm bolts holding it on. when you change your oil in the honda you need to drain BOTHplugs. one is at the bottom of the tank the other is under the engine. hope this helps ya.
Old Aug 31, 2006 | 01:15 PM
bamurf80's Avatar
Thanks for the info. I did'nt see a plug on the bottom of the tank all i saw was the oil line that goes in towards the bottom of the tank is that what i remove? Also when i put the new oil back in do i need to prime anything or just put oil in the tank and it will cycle it self?
Thanks,
Bamurf80
Old Aug 31, 2006 | 01:27 PM
hondabuster's Avatar
click here
This should help answer your questions..even has pics.
Old Aug 31, 2006 | 03:06 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Nice link, hondabuster! It will save a lot of explaining later, as these questions pop up all the time.
Old Sep 1, 2006 | 01:47 PM
bamurf80's Avatar
thanks guys for all the help!!!! I am slowly learning about hondas.
Bamurf80
Old Sep 1, 2006 | 04:14 PM
no problem, thats whatwe are here for. enjoy your 400.
Old Sep 1, 2006 | 07:05 PM
mack63's Avatar
Remember to put the filter in the correct way. The filter will say which side faces out.
Old Sep 3, 2006 | 01:12 AM
bamurf80's Avatar
I changed the oil yesterday. The person before me put the filter in the wrong way when they changed it and i don't know how long it has been that way. I hope it didn't mess anything up. I didn't see anything strang in the oil.
Old Sep 3, 2006 | 10:08 PM
That unfortunetly is very common, especially when someone uses a emco filter or one like it. They dont have any print on them saying which way is out.
Its also a bad design, it should be dummy proof, so the thing can only phyiscally installed the correct way. Like the external metal case, filters.
Kyle5050
Dec 13, 2019 04:25 AM
MNatv89
Aug 10, 2015 02:20 PM
toonces
Aug 5, 2015 05:55 PM
coolguy420
Jul 28, 2015 01:54 AM
yambam13
Jul 4, 2015 01:49 PM
