Can you run an 400EX with no airbox lid?
Old 09-28-2006 | 07:03 AM
pumpkin's Avatar
Default Can you run an 400EX with no airbox lid?
I know some machines run better with the lid off. I do it on my lt450r. I have a buddy that does the same thing on his 400EX. Can this be harmful to his machine?
Old 09-28-2006 | 10:39 AM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Not if he rejets the carb.
Old 09-28-2006 | 10:54 PM
Honda4's Avatar
Yep only if he rejets.
Old 09-29-2006 | 10:52 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
If you don't rejet, you will run lean (Hondas are jetted lean to begin with, to meet emissions specs), which means you will run HOT, and you can toast your engine!
Old 04-25-2007 | 03:21 AM
rockroller's Avatar
ok well how bout after a jet can you leave the box lid on? or is this now harmful? i'm putting a lte just need to save 300 more bucks. it comes with a aluminum air box, jets , but no air box lid. so my buddy said he would make on for me! i need the lid for were i ride, so this being the case, is the lte not the one for me?
Old 04-25-2007 | 09:01 AM
RedRubi's Avatar
Not a problem if you don't mind rebuilding your engine every 100 miles from dirt taking the pistons rings and bearings out.
Old 04-25-2007 | 10:53 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
It will fine fine as long as you clean and oil your airfilter often.
BUT, I recommend getting a EHS or K&N high flow lid just to be safe. That is what I do with my machines and they have all been fine.
Old 04-25-2007 | 03:33 PM
scottphillips88's Avatar
Just be carefull once you remove all your airbox stuff. The airbox was put on their for several reasons. One of the major reasons is water. Don't wash your machine without covering the air filter with a plastic bag...Also be carefull when riding in wet conditions, it doesnt take much to ruin your day.
XxS0ccerstarxX
09-25-2015 12:53 AM
XxS0ccerstarxX
09-24-2015 06:38 PM
XxS0ccerstarxX
09-24-2015 03:02 PM
XxS0ccerstarxX
09-22-2015 03:40 PM
mbriggs
09-13-2015 11:47 AM
Top
Follow Us
