Wiring Diagram
Old Oct 14, 2008 | 01:48 PM
  #91
hondatrxbroken's Avatar
Default Wiring Diagram
sent you a pm hondamechanic
Old Jan 27, 2009 | 02:55 PM
  #92
yotatrailrunner's Avatar
Hello HM, I just got done repairing a top end on a 86 TRX350 fourtrax. I had the quad running great and all of a sudden it just quit. I can not tell if the fuel pump is coming on or not. Can you send me a copy of the wiring diagram and a theory of operation for the fuel pump? Thanks. yotatrailrunner@hotmail.com
Old Jan 27, 2009 | 04:11 PM
  #93
HondaMechanic's Avatar
I emailed you a couple of sections .. When you turn on the key/ignition , then touch the electric starter button for a second , you should hear the fuel pump rattle for a few seconds (or feel it rattle if you touch it ) ...
Old Jan 27, 2009 | 08:51 PM
  #94
thank you very much. were exactly is the fuel pump relay located?
Old Jan 28, 2009 | 04:37 AM
  #95
The relay is inside the little box (with 4 phillips screws) located beside the right rear wheel ..
Old Jan 28, 2009 | 08:45 PM
  #96
whitelightnin3006's Avatar
Honda Mechanic, would you happe to have the wiring diagram for a 2001 honda rancher 350 es? Here is why http://forums.atvconnection.co...tid/8/threadid/559517
Thanks and if not no biggie, have a good one
Old Jan 28, 2009 | 09:14 PM
  #97
Yes I have a wiring diagram fo a 2001 TRX350FE ... PM your email address and I will email you the wire diagram section ...
Old Jan 29, 2009 | 12:17 PM
  #98
Thanks, Looks like I have other problems, If I unhook the hoses to the fuel pump the fuel pump runs, as soon as I attach the hose to the carb it quits. guess it is supposed to work like that. Tried to jump the relay and that did not change anything. Im starting to think the float is stuck closed or somethingin there. You have any ideas?
Old Jan 29, 2009 | 01:38 PM
  #99
That sounds like you have carb trouble ...
Old Jan 29, 2009 | 03:57 PM
  #100
HONDAFUN82's Avatar
Hello,
I have a 1987 TRX350D and im not getting any spark, does anyone have a wiring diagram they can email me? my email is dakotasrt8@yahoo.com. i think maybe its the trigger pulse coil, does anyone know how to test it to see if its good, id be thankful for anyhelp i can get
