Wiring Diagram
Old Apr 10, 2009 | 10:49 PM
  #111
stonehouse's Avatar
Default 30 TRX350FE won't shift
I have an 04 TRX350FE that won't electrically shift. It started after I forded a small creek, but cleared up after turning off. It's been sitting for a couple of weeks now, and I went to use it today and it started fine, but won't shift. The display just flashes the "N" in a repeating pattern. Any clues and/or wiring diagram would be greatly appreciated.
Thanks.
AM
thewirewhisperer@gmail.com
Old Apr 11, 2009 | 04:52 AM
  #112
HondaMechanic's Avatar
You first have to count the number of flashes .. If you have to do a code retrieval this is how..
Old Apr 15, 2009 | 03:43 PM
  #113
stonehouse's Avatar
When I turn it on, I get 3 flashes of the shift indicator, a gap then it repeats the 3 flashes...
Thanks!
AM
Old Jul 25, 2009 | 12:46 PM
  #114
tireman_wiz's Avatar
Default yeah i need help also
I came across an old honda odyssey and soon after i purchased it i noticed it was not the original engine. The motor seems to have come off a trx350 sometime in between 1986 and 1989. i have what looks to be the coil and cdi box off the fourwheeler also. None of it is hooked up so i need a wiring diagram for the cdi,coil and igniion. Thats probably will help me out alot. My email address is tireman_wiz@yahoo.com
Old Aug 24, 2009 | 10:46 AM
  #115
ucboo's Avatar
Could I also get a copy of the wiring diagram for the TRX350?
EMAIL:ucboo71@yahoo.com
Old Aug 25, 2009 | 05:08 AM
  #116
Did you get this figured out ..?
Old Aug 25, 2009 | 05:09 AM
  #117
What year TRX350 ..?
Old Aug 25, 2009 | 08:16 AM
  #118
ucboo's Avatar
It is a 1986 Honda TRX350.
Old Sep 11, 2009 | 04:08 PM
  #119
vwaudifreak's Avatar
Default 88 TRX300 wiring
Hi,
I'm looking for a wiring diagram for a 1988 TRX300 FWD.
Thank you!
vdub_guru@comcast.net
Old Sep 12, 2009 | 06:29 PM
  #120
If you didn't find the wiring diagram yet PM your email address..
