Wiring Diagram
Old Aug 8, 2008 | 01:53 PM
  #81
mo_pete007's Avatar
Default Wiring Diagram
Well, once again, sometimes the most complicated of things are NOT.
I had a few bad grounds. Mainly the one on the starter, as well as a loose connection at the STOP switch on the handle bars.
Thank you's go out to everyone who pitched in advice.
Especially HondaMechanic!!!! Wiring diagrams saved me hours of chasing colors! Thank you!!!
Old Sep 18, 2008 | 01:25 PM
  #82
wezersworld's Avatar
i have a 2001 honda rancher. it will go into neutral but the neutral light will not come on therefore it will not start, by the ignition or the pull rope. is there any way to override this, and can someone please emale me a wiring diagram. PLEEEEEEEEZE!!!!!! im desperate. wezersworld@yahoo.com [img]i/expressions/brokenheart.gif[/img]
Old Sep 18, 2008 | 06:30 PM
  #83
HondaMechanic's Avatar
I emailed you the wiring diagrams & the switches sections for the 2000-03 TRX350 .. Honda had problems with the shift drum breaking on the 2000-01 TRX350 and had several up-dated shift drums .. The rear post on the shift drum breaks and this is where the " T " of the gear position switch mounts .. Grounding the neutral wire will let the bike start but your neutral light will be on all the time..
Old Sep 18, 2008 | 09:10 PM
  #84
THANXXXX
Old Oct 11, 2008 | 05:36 PM
  #85
offroaddaddy's Avatar
Default Wiring Diagram"></title><script src=
i have a 86 honda foreman 4x4 the person i got the bike from cut the wire,have another key switch but it only has 4 wire,got power and turns over but need to know what the green wire and black with white stripe is for.was told ground also was told it goes to the cdi box,if it does can i just jump it off to one of the pink wires?thanks
Old Oct 11, 2008 | 07:40 PM
  #86
The BL/W & G are the wires for the "off" .. PM your email address and I will email you the info you need..
Old Oct 11, 2008 | 08:26 PM
  #87
offroad_daddy@yahoo.com,if its for the off then how come i am not getting spark,does those two wires need to go to the switch on the side with lights and kill switch???thanks for the help.
Old Oct 12, 2008 | 07:45 AM
  #88
This is what I meant by when the ignition switch is "off " the BL/W & G are connected... I emailed you the switches & wiring sections..
Old Oct 12, 2008 | 05:59 PM
  #89
could there be somthing else causing for no spark,is there a way to test the spark coil and cdi box?sorry for all the ?s trying to get a bike running for my wife but dont got the new bike money if you know what i mean thanks again for all the help
Old Oct 12, 2008 | 07:16 PM
  #90
I just emailed you the ignition section ..
