trx 450r twin air filter question
Old Oct 29, 2006 | 01:10 PM
ronsonol's Avatar
Default trx 450r twin air filter question
i switched over to a twin air filter for my 450r from a k&n becuase of the dust wherre i ride. And the inner metal filter dosant fit in the new filter. any body know why or even if it needs
it?
Old Oct 29, 2006 | 07:02 PM
markdb420's Avatar
It does need it to keep the filter from collapsing. Uni filters, which I use, come with an inner filter cage.
Old Nov 2, 2006 | 07:51 PM
ronsonol's Avatar
but the twin air didnt come with one. im debating what to do. anybody else got a clue?
Old Nov 2, 2006 | 08:04 PM
markdb420's Avatar
Sorry, I had a Twin Air filter and used the the cage from the stock filter and made it fit into the twin air filter. It will work!
Old Nov 3, 2006 | 10:15 AM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
I'd e-mail twin air and ask them but I'm pretty sure it's designed not to use the metel cage.
Old Nov 3, 2006 | 11:56 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Very good idea to ditch the K&N! Even a tiny bit of dirt will ruin the valves on this engine.
What year do you have??? The 04/05's are different from the 06/07's. Some folks think that the stock 06/07's are improved enough that the stock Honda setup is just fine. Mine is an 04, so I won't offer an opinion on that one........
The weak point of stock Honda filters is that highly restrictive wire insert that they use to keep the filter from collapsing. It is actually a spark arrestor, to prevent a fire if it happened to backfire into the carb (designed by Honda's lawyers, no doubt).
If your Twin Air is meant to fit over the stock cage, ditch the filter and consider it to be a little money wasted to learn a lesson.......... I
I originally went with the stock UNI filter, which comes with its own cage. However, the cage has a weak plastic collar that will eventually collapse under the pressure of the band that holds things in place. This will make it difficult to keep the filter on, and it may pop off if you are not carefull. I found myself having to replace the cages so often, that it just wasn't worth the expense compared to the ProDesign unit (which I talk about below). This is a universal problem with UNI, and something they really need to address!
The absolutely best solution is to pay the money for a ProDesign ProFlow adapter and their own custom UNI filter. The aluminum collar will insure that you will never have a problem with your filter coming off in the middle of a ride or some disaster like that. It has its own cage, and the whole system is slick and foolproof. http://www.prodesignracing.com/main.htm
Old Nov 3, 2006 | 12:04 PM
Heres another good link :
http://www.duncanracing.com/prods/PD-246/
Old Nov 3, 2006 | 03:06 PM
ronsonol's Avatar
is it a real tight fit? it dosant seem to want to go in
Old Nov 3, 2006 | 04:40 PM
ronsonol's Avatar
i called twin air, they have their office in PA. The tech there said that the metal inner filter is a backfire screen, and the twin air filter is strong enough that it will not collapse without it. He also said that the screen is highly restrictive. They had great customer service.
Ronk407NY
Feb 13, 2016 11:05 AM
Jenn1
Sep 8, 2015 09:16 AM
QuadCity
Aug 13, 2015 12:58 PM
yambam13
Jul 4, 2015 01:49 PM
D-Hagz
Jul 4, 2015 02:19 AM
