stator assembly help
Old Dec 14, 2006 | 05:25 PM
tymann09's Avatar
Default stator assembly help
some of you may have seen my other post awhile ago regarding the battery, lights not working etc....well i performed a charge coil resistance test, there are really 2 tests invloved and it said if i failed both, that i need to replace the stator assembly, because i have a faulty charge coil......so, in order to replace the stator assembly i need to get into the alternator cover which the book shows is alot of work then i need to replace the stator assembly.....my question to you guys is, is this as hard a job as it looks or should i just take it in and spend a billion dollars, its a 2004 honda recon by the way....thanks- tyler
Old Dec 14, 2006 | 06:57 PM
tymann09's Avatar
problem solved, im paying a billion dollars and taking it in
ultangler
Nov 30, 2024 01:35 AM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
