metal shavings in oil, honda 400ex
Old Jan 1, 2007 | 11:29 PM
theory6's Avatar
Default metal shavings in oil, honda 400ex
My buddy has been having problems with his quad starting up, he thought it could be a jet problem especially since we went to california for the weekend and are normally in higher elevation in tucson. he just drained the oil when we got back and a few metal shavings dropped out with the oil and we're not sure where this is coming from... any ideas at all would help...thanks
Old Jan 2, 2007 | 02:28 AM
JLsparky7's Avatar
Steel or aluminum? use a magnet and check.
Old Jan 2, 2007 | 03:20 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
In the oil filter, in the tank, or in the sump when you drained it??????
Old Jan 2, 2007 | 01:12 PM
theory6's Avatar
its aluminum, magnet didnt move it at all...
it was bored out from a 400 to about a 460 by someone he bought it from, and he usually has to replace the oil after 10 hours or so.. the shavings came out when we unscrewed the screw on the bottom of the tank.. not the oil filter.
http://i50.photobucket.com/albums/f3...6/P1010047.jpg
http://i50.photobucket.com/albums/f3...6/P1010044.jpg
Old Jan 2, 2007 | 01:27 PM
bombrider04's Avatar
Well if the oil was never changed from when it was bored otu I would say it's from that but I would def get it looked at and get the shavings out of the engine...check the bore to see if you can see if there are any signs of scraping on the cylinder walls.
Old Jan 2, 2007 | 02:17 PM
theory6's Avatar
yeah it was changed a few times since it was bored... i appreciate the help..
we'll look at the cylinder walls today and probably post again heh... thanks dudes
Old Jan 2, 2007 | 08:26 PM
bubba1969's Avatar
how big were the metal shavings? you may want to try to flush the engine also. worst case scenario would be to disassemble the engine and inspect and clean everything.
Old Jan 2, 2007 | 08:43 PM
theory6's Avatar
alrighty, yeah I got these pictures here of what they were like...
shavings in hand
Old Jan 3, 2007 | 12:26 PM
theCATman's Avatar
Looks to me like threads from either the drain plug, or the tank bung.
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
Asaran
Oct 8, 2015 11:14 AM
Huntingdeer
Aug 23, 2015 12:06 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
