99 Honda 300 4x4
99 Honda 300 4x4
you will be fine, i think the 300 were the best/bullet proof atvs ever. good low end too. you WILL lose some top end though! as far as a 12 inch rim you can pretty much get any tire you want. try a gator, or mudbug if you want a more aggressive tire(not to aggressive) or maybe dirt devil for a less aggressive tire.
99 Honda 300 4x4
Honda now gears its 4wd's a little higher in back than in front (the tires are the same size front and rear). This takes the pressure off the front end until the rear end actually begins to slip a little. This insures lighter stearing that won't "fight" you when you are just cruising around.
What I think they did in the old days with the 300, is just put slightly taller tires on the back than on the front, and this accomplishes the same thing in the end.........
99 Honda 300 4x4
I'll add on to this one as well. I too own a 99 TRX300 4x4 and would like to put on some stock 06 rims from a Foreman onto my TRX. With all the 300s around I cant believe that someone hasn't done this before. The tires on the forman are F: 25x8x12 and R: 25x10x12. Perhaps someone has a pic or can say wheather these will work with no problems. Can anyone who has experience help us?............Thanks,
TRX300
TRX300
