Newbie can't start 03 Foreman Rubicon
Hey guys-
Found the primer - didn't do a thing -- found the air intake, covered it partway, exactly the same sounds and results. I'll get a service manual online and that should help me a ton. I have no problem following visual instructions [img]i/expressions/face-icon-small-smile.gif[/img] Thanks!
The spark plug is probably questionable at best, while its inside and getting warm, put a new plug in before trying to start it again. Then, while the plug is out of the head, do a spark check to confirm the spark is there.
How long has it been since the valve clearance was adjusted? If the intake valve tightens up, the compression will drop dramaticly...leading to a no start.
#15
#16
#17
(these things don't even turn over with the kill switch off. I hit it once and took me a second or two to figure out why it stalled and wouldn't turn over )
I beg to differ, they will turn over. I, in fact was hauled (pulled) out of a deep woods trail one night, was cussing Honda like a mad man as we were getting ready to load in on a trailer only to discover that I had in fact hit the kill switch while going over a large log. My hand had hit it when the wheels jerked...
I then later for my birthday rcvd a nice atv shirt with the name "KILLSWITCH" printed on the back.
Mine is an 2002, and after telling my dealer this funny story, He said they see many atvs come in "that wont start" Only to discover the kill switch is off.
Text
Text
#18
Maybe just my 2004 Rubicon will not turn over when handle bar kill switch is off? I know it used to be the way you describe. That is why I didn't bother looking at the kill switch, because it wouldn't even turn over.
Could my Rubicon be broken? I guess so, but it has worked like that since day one. It only makes sense that it's like that, so unsuspecting people don't kill the battery. I have a friend that hits the kill switch to shut it off, when I get on it and it doesn't turn over I know what the problem is right away. If it is broken, I'm keeping it that way. Thanks.
#19
Originally posted by: propnut
Your story is similar to mine, but I caught the switch being off before I had to be towed.
#20
