400 Ex Swing arm Bearing replacement
Old Jan 15, 2007 | 08:49 PM
SherpaT350's Avatar
Default 400 Ex Swing arm Bearing replacement
How hard is it to replace the swingarm bushings on a 99' 400 ex ? About how many hours would a shop charge to change the bearings ? I am just wondering if I want to do this myself or have a shop do it.
Thanks,
D.
Old Jan 16, 2007 | 05:29 PM
billybanshee400ex's Avatar
wich one in the front of swingarm or im on the axle ????
Old Jan 16, 2007 | 06:29 PM
SherpaT350's Avatar
axle bearings
Old Jan 16, 2007 | 06:31 PM
its very easy to change it you're self it take about 1 hour its not hard
Old Jan 16, 2007 | 06:35 PM
SherpaT350's Avatar
So, if you haven't done it before, a couple of hours to change the seals and bearing out to be enough ? Do you just remove the axle from the carrier and then bring the whole carrier to the bench and take it apart ?
Thanks,
Old Jan 16, 2007 | 08:53 PM
carlw's Avatar
order bearings seals and a repair manual. you can get a 3 for about 50 bucks total . and then do it yourself. it is very basic.
Old Jan 19, 2007 | 10:09 PM
SherpaT350's Avatar
WOuld someone be so kind as to tell me of a website on line that has the pdf file for a 99' 400ex ? I mainly only need the couple of pages that tell the swingarm disassembly but would look at the whole manual if it was available.
Thanks,
D.
Ean
Dec 19, 2022 08:48 AM
Peter_
Jul 18, 2015 07:06 AM
Chuck188
Jul 17, 2015 02:45 PM
joeyupton
Jul 14, 2015 11:51 AM
clsharky
Jul 13, 2015 02:07 PM
