how to test a coil
Old Jan 19, 2007 | 08:00 PM
zizmet's Avatar
Default how to test a coil
hi i would like to know if it's possible to test a coil at home and how to and with what how to use it
thanks,max
Old Jan 19, 2007 | 08:13 PM
2manytoys's Avatar
You need an ohms meter. You also need to know the specs for the coil. Once you have these all you need to do is connect the meter to the coil power and ground and read the ohms.
Old Jan 19, 2007 | 08:20 PM
bombrider04's Avatar
If you don't have an ohm meter then what I would suggest is getting a multimeter that way incase you need it to test other things such as ac/dc current
Old Jan 20, 2007 | 11:08 AM
zizmet's Avatar
ok thanks i think i will just send it to a garage
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
zPuls3
Sep 12, 2015 08:54 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
MrTrashMan2U
Sep 9, 2015 11:11 AM
