Engine Ice
Old Jan 24, 2007 | 07:51 PM
redrider03's Avatar
Default Engine Ice
I was just wondering how to drain all the old coolant out so I can put the new stuff in. Should I just pull off the bottom hose on the right side like I planned on or is there a drain plug somewhere that I overlooked. I'm going to put some Engine Ice in it. Has anybody used this? What are your opinions of it? So far I've only heard good things. Thanks in advance! Red
Old Jan 24, 2007 | 08:10 PM
aaaaaaa's Avatar
Default Engine Ice
go ahead and pull that hose out and drain it. be careful and just don' t break it. i dought you will so don't worry and pull it out.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 24, 2007 | 08:13 PM
bombrider04's Avatar
Default Engine Ice
before running the engine ice I want to warn you ...it is great and I have it in my ds 650 curretly, but there has been problems with people not flushing out the old coolant thoroughly before running the engine ice and this has caused film in the cylinder. So what you will want to do is drain the old stuff out and once that is done run some water through and get all the antifreeze out...once that is established fill her up with engine ice and your set to go.
Old Jan 26, 2007 | 01:00 PM
redrider03's Avatar
Default Engine Ice
Sweet, thanks for the info. Red
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
