84 200e 3wheeler
Old Jan 24, 2007 | 08:17 PM
loadder's Avatar
Default 84 200e 3wheeler
back for more, got the shifter welded on and its solid, kids were riding and it started to idle very high, then just cut out, i got it started and it bogged when i gave it gas, so i took carb off, cleaned it and put back together, ? is ; is there a spring associated with the needle ? that i may have lost
i can spray carb cleaner into butterfly and push start it, and it dies as soon as its burnt off, gas gets to the bowl, but does not seem to come up thru the carb to do its thing, can this be the pitcock valve?
i took off tank and gas runs thru it, mabey not as much as it should, but the bowl is full when i try to start it, i still dont have the correct pull start assembly , got one off ebay but it is for a diff fly wheel pully thingy (basket) what ever the pull start gear is supposed to grab onto, anyway thats a different problem, more interested in the carb right now, any help is always appreciated, thanks and keep it real
jimmy
Old Jan 24, 2007 | 10:06 PM
rdeeno's Avatar
First open the drain on the carb to see if fuel flows out. If you have a good steady stream, that should be good enough. Is this a 200es, I believe the motor is the same as my 84 trx200. Bikebandit.com has the oem parts catalog with pics which my help with your carb question.
Old Jan 25, 2007 | 03:54 AM
JRM's Avatar
JRM
honda made 3 200 3 wheelers in 1984
200s simple chain drive with no suspention
200m 5 speed chain drive with lights
200ES big red, dual range shaft drive with lights and 2" travel on front end
All 3 use the same basic engine design as the XR200R of the late 80's and 90's
Old Jan 25, 2007 | 12:33 PM
num482's Avatar
Yes and no, My 1984 200s had front suspension and lights.
oldschool64
Aug 12, 2015 07:13 AM
sharpie
ATC 3-Wheelers
Mar 19, 2004 06:26 PM
wildchild660R
ATC 3-Wheelers
24
Feb 11, 2003 07:53 PM
albaBANSHE
ATC 3-Wheelers
Jan 7, 2003 01:23 AM
ThreeWheelio
ATC 3-Wheelers
Jan 31, 2000 12:51 PM
