shocks and springs
Old Feb 15, 2007 | 08:18 PM
hondafornow's Avatar
Default shocks and springs
Can anyone tell me how to take apart the shock from the spring on the back shock of 2003 350 rancher
andthe front shocks of 1991 300 trx
tks so much
Old Feb 15, 2007 | 09:30 PM
Airbrushhead's Avatar
If you're wanting to take the spring off the shock, here's what you do:
There are two rings on top, one is jammed against the other. Use shock wrench or a big screwdriver and hammer and loosen top ring(It has notches on both).Unscrew both rings and take completely off. Spring is now loose as it will be.There is a plate with slot in it, it will need to come off. If you have someone to help, take two screwdrivers and insert them in between first two coils and push down, Have someone slide the plate(retaining plate) out letting slot slide past shaft. May require alot of arm pressure, so be careful. Once you do it once, you can do it blind-folded. A good vise would be great to hold shock. It's easy.
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
