Help With my 400ex
Old Mar 20, 2007 | 11:52 AM
Lifes2ShortRideHard's Avatar
Default Help With my 400ex
I put the 426 big bore kit in my EX and a stage 1 Hotcam. And i tapped out the studs in the motor and made the bolts bigger b/c it kept blowing head gaskets. I have put prolly 3-5hours on the motor since then. I was using 93 octane gas and then i filled it up with 87 gas. Now every time i gun the throttle it makes a ticking sound in the motor. Is this b/c of the gas or something else?
Old Mar 20, 2007 | 12:32 PM
yz426ex's Avatar
detnation. What compression is it? You should use 93 or higher for sure
Old Mar 20, 2007 | 01:27 PM
it is either 12:1 or 11:1.
Old Mar 20, 2007 | 02:02 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
The STOCK engine requires 92 octane!
Old Mar 20, 2007 | 02:08 PM
yz426ex's Avatar
You should use 100 oct or higher.
Old Mar 20, 2007 | 02:12 PM
Thanks alot guys
Old Mar 20, 2007 | 03:30 PM
yz426ex's Avatar
cant use octaine booster to bump it up either.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
