250x has no spark
Old Apr 5, 2007 | 07:58 PM
jm69's Avatar
Default 250x has no spark
I was wondering what could be bad if i have no spark? Or what usally goes out? I have an honda 88 250x. Thanks
Old Apr 6, 2007 | 12:05 AM
shooter7448's Avatar
Hello jm69,
A loose connection is the usual problem but if a part is out I would say the odds are the coil first (which can be tested) then the CDI (cannot be reliably tested except to swap for a known good one). What tests have you done?
I am having a problem as well with a 250X firing, posted at this thread:
http://forums.atvconnection.com/mess...did/516365.cfm
Perhaps you could help me out I sure could use those colors
Old Apr 6, 2007 | 12:45 AM
TommyA300's Avatar
NO SPARK ?
When was the last time it was running and how did it come about?
Items in a list to check out!
1 spark plug
2 ignition coil
3 ignition module
4 pulse generator
5 A.C. Regulator
6 kill switch.
7 wire came loose
8 ignition switch
Old Apr 6, 2007 | 07:06 AM
jm69's Avatar
I was riding it and it just quit. I have checked the coil and it should measure between like .1 and .2 ohms. I got a reading of .3 ohms. is that enough to call it bad. Thanks
Old Apr 7, 2007 | 01:10 AM
300exStroked's Avatar
possibly a bad rectifier.. also, I was having trouble with mine.. turns out it was the wires that go to the reverse/neutral switch down by where the reverse cable hooks up.. up under that cover. I'd take that multi-meter and individually check every wire. Happened once before that one was barely burnt through causing it not to spark, but it was just enough. Took me forever to find it.
Old Apr 12, 2007 | 07:51 PM
jm69's Avatar
I checked everything and it seems that the reverse switch is bad. Would that cause me to get no spark? thanks
Old Apr 12, 2007 | 09:06 PM
yes, if it is bad i believe it thinks that it is in reverse thus giving you no spark.
Old Jun 12, 2007 | 01:06 PM
dwm30's Avatar
I have the same problem with mine I believe. I check the wires going to the switch with an ohm meter and it has continuity no matter if its in reverse or not, so I thing my switch or wires may be bad.
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
