Compression ratio and Cam 400ex
Old May 22, 2007 | 01:54 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Default Compression ratio and Cam 400ex
So, I plan on getting a cam for my big bore 400ex soon. I ride a trails and do a lot of dirt hill climbing similar to dunes. I've narrowed it down to Hotcam stage 1 or 2. I have read a lot of mixed ideas on these cams. I've read ppl say stage 1 is bottom mid power, stage 2 is mid top but everywhere i look to buy the description says stage 1 boost all around stage 2 recommended for big bore with more boost on top.
I'm looking for max mid range. I feel i have plenty of bottom. Now I know that i need higher compression for the stage 2 to keep from losing 2 much bottom. But I didn't build this 440.
1.)Is there anyway to find my compression ratio?
2.)Anyone out there with the experience of stage1 vs stage 2 HotCam?
Old May 23, 2007 | 10:27 AM
Koopa's Avatar
Site went down again last night. Guys probably still working bugs out.
Dennis Kirk had yet another description for the stage 2 HotCam it said Engineered for MX and Desert racing needs. Well, I'm not going to be doing that. But its reccommended for bores over 426 but, i still need to know if my compression is ok to keep from losing power down low right? Do i need 11.5 : 1 or would 10:1 be sufficent. I'm sure I'm running at least 10:1 being big bore.
Old May 23, 2007 | 11:16 AM
TwinCam95's Avatar
Whatever compression ratio you have with your big bore kit will be sufficient with either cam. If you get the stage 2 cam you will need to also buy yourself a rev box/higher revving ignition to take full advantage of that cam. If you don't like revving the motor beyond what honda intended, then stick with a stage 1. It still gives you much more in the midrange and power up top than the stock cam, and works nicely with the stock ignition.
Old May 24, 2007 | 11:24 AM
Koopa's Avatar
Why does HotCam say that the stage 1 is not recommended for bore's larger than the 426.
Old May 24, 2007 | 12:54 PM
TwinCam95's Avatar
That's probably a question to ask them.
Old May 24, 2007 | 12:58 PM
Koopa's Avatar
Your right. I think I'm going to call and chat with the guys at HotCam. Thanks for your help TwinCam95.
rockinkgin
Sep 25, 2015 01:52 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
