Do I need a tork wrench
Old Dec 26, 2000 | 09:57 PM
PsychoRecon's Avatar
Do i need a tork wrench to mount my new tires ? i got them with brand new rims and all. My dad says we need a tork wrench but i am not so sure thanks for the info
Old Dec 26, 2000 | 10:20 PM
tprender's Avatar
They do give spec's for what they are supposed to be tighten to, but I have never seen anybody use one. I use my 1/2 in ratch with a 6 in extension and get them as tight as I can.
Old Dec 26, 2000 | 10:30 PM
DIEhardRlDER's Avatar
I dont use them on my wheels. BUt i try to use them on everything else that serves a purpose. NOt my plastic and cosmetics. JUst tight as u can
Old Dec 26, 2000 | 10:41 PM
ok so how tight should i get the bolts without going to tight ot to loose ??
Old Dec 26, 2000 | 10:57 PM
scramdaddy400's Avatar
Okay, 85% of your quad is a torque spec. so go out and buy yourself a cheap torque wrench for about $20 bucks, then do the job right instead of playing the guessing game.
You know the thing is going to have 101 other uses on your quad so its worth every penny to buy one.
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
Old Dec 26, 2000 | 11:38 PM
I dont necesarilly want to spend the money on one if i dont need it. AND if im gonna buy one im not gonna buy a cheap one ill buy one that will last
Old Dec 27, 2000 | 01:00 AM
KrazyNeighbor's Avatar
forget the wrench dude.... unless your getting into the engine or something
Old Dec 27, 2000 | 10:38 AM
bluGill's Avatar
If you don't have one, don't worry, tires are not critical. However dont' tigheten them down as much as you can. Find out what it shouodl be and try to guess. Generally torque is measured in foot-pounds, which means that if your wrench was one foot long you would apply that many pounds to the handle.
Wheels are cars are generally about 100 lbs. Going too high can do damage. (If you tighten the nuts in a star patteren it is much less likey to do damage, if you don't even a torque wrench won't prevent damage) I'm not sure how a quad relates. as I haven't worked with my wheels much.
Don't touch the engine or transmission without a torque wrench. If you have a torque wrench use it for everything you can find with torque specification. If you don't have one, you don't strictly need it for minor stuff, but I recomend it. Put it on your birthday wishlist, unless you need to tear into something critical before then.
Old Dec 27, 2000 | 02:45 PM
exer's Avatar
If I were you I would get a torque wrench. Don't just go out and buy a cheap one. I would suggest buying a click type and not the one with the pointer indicator. Always reset the wrench to zero after EVERY use, this will eliminate the need for frequent recalibration. Torque specs are put in the manual for a reason, overtightening is very common and will cause parts to distort, and I think you know what undertightening will result in. Always use the specs, you will be happy you did in the long run.
Exer
Old Dec 27, 2000 | 02:46 PM
Jeff250r's Avatar
Talking about tork specs.....
OK fellow 400ex'ers... What does th shop manual say for the head pipe. I'd buy the book but it's my buddies quad. I still ride the "king" of all time.
PS...any tips on jetting ? Should he do a stage 1 or 2. He put on a FMF Cherry Bomb Header, with powercore muffler. K&N Precharger. No other work planned for tghis quad. Live at sea level, ride about 50% here and 50 @ 3000 ft elevation !
Lates...
