400ex stalls in water
Old Jun 22, 2007 | 05:42 PM
muddstudd's Avatar
Default 400ex stalls in water
Scootergptx is right about the vent hose, it is the drain that hangs down but it's closed off unless your draining your fuel bowl
Old Jun 22, 2007 | 05:45 PM
muddstudd's Avatar
how fast do you hit the water? I go through a mud pit by my house all the time and its almost above the tires and mine doesn't cut out. i don't even have my airbox on anymore. anytime i cross water i allways go a slow as possible though.
Old Jun 22, 2007 | 05:50 PM
mizzou_17's Avatar
i do not go fast at all but i know when you ride wheelies and stuff gas will occasionally run out of the overflow tube on the carb, can water get in it?
Old Jun 22, 2007 | 06:03 PM
muddstudd's Avatar
the carb has an internal passage that connects the drain tube to a tube going to the top of the fuel bowl. when it tips up or over fuel can travel through that internal tube and trough the drain tube. i don't see how water coud get in through that tube but you might try blocking it off. you'd think if water could travel through it all the guys that install snorkal kits and do deep water crossing would have thiers blocked off.
Old Jun 25, 2007 | 03:19 PM
  #15
mizzou_17's Avatar
filled spark plug boot with dielectric gel and seemed to help alot but still had some sputters in 8 inch deep water any other ideas
Old Jun 25, 2007 | 03:22 PM
  #16
mizzou_17's Avatar
i also relocated the carb vent hose to the handlebars and checked all intake tubes and they are all tight
Old Jun 25, 2007 | 09:51 PM
  #17
buckaroo50's Avatar
If your exhaust exit gets under water it will cause your engine to bog down and die.
Pehter
Oct 3, 2024 11:00 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
