ATV Strobe Lights
Old Jan 2, 2001 | 10:12 PM
MrElussive's Avatar
Hi,
Does anyone know where I can get an ATV strobe light from? I like to ride with friends at night and perhaps a strobe light would increase visibility. I don't mind if the light is battery powered, I just need something I can securely mount on both of my quads.
Old Jan 2, 2001 | 10:20 PM
mxquadracing's Avatar
Strobe lights....Strobe lights flash on and off. Are you just looking for brighter lights?
Old Jan 2, 2001 | 10:21 PM
NewDSLover's Avatar
Check a local Marine shop, they should have 12v lights that you could adap to a quad.
Old Jan 2, 2001 | 10:54 PM
Tree Farmer's Avatar
Have you checked out a yuppie bicycle shop? I've seen bicycle riders at night with flashing strobes attached; low light-level (compared to a 747), but probably adequate for quad-riding distances, especially in the woods/on trails at night.
Another possibility is the flashing or rotating warning or emergency service vehicle light, called by some the "Kojak" light. Plugged into 12 volts, with a magnet or permanent base, these jewels are available in various colors (like, yellow); your Pep Boys or similar auto parts and accessory store should carry 'em, surely, J.C. Whitney does, AW Direct (800) 243-2194 has a jillion of 'em (like # BR-65, amber teardrop magnetic rotator, $ 19.95).
Tree Farmer
Old Jan 3, 2001 | 12:18 AM
MrElussive's Avatar
Okay, I found some lights. I would like to add a light or two on the front for brighter night driving. I found this light that mounts to the front or rear racks:
http://store.yahoo.com/azmotorsports/56-1045.html
Do you people think that would be sufficient as a third light?
I found a strobe light that seems to be sufficient.
http://www.outdoor-catalog.com/coonh...robe_light.htm
I am going to buy one of these strobe lights and if I like it, I'll buy three more and put two on the back of each quad. That would look pretty cool. =)
Old Jan 3, 2001 | 01:41 PM
patrailrider's Avatar
I think I might have a perfect strobe solution for you. I decided to get one this fall to use while plowing. My driveway is shared by several families, and traffic can be busy by the main road.
I got a Whelen 2022 Strobe light from Sirennet.com. This strobe is one of the brightest and has multiple strobe patterns, yet doesn't draw much power.
Simply get a 1" dia. piece of PVC conduit used in underground electrical work, attach a threaded adapter on one end, and insert a 1" dia wooden dowel in the other end.
Attach the pipe to the strobe via the threaded end ( Whelen strobe bases have the threaded adapter built right in). Drill a hole through the center of the wooden dowel and attach it to the flag mast mount on your rear rack with a wood screw / bolt.
Power can be provided via the accessory lighter plug, or add a lighter outlet in the rear as I did.
Mount the light just high enough to clear your head, that way it can be seen 360 degrees. Works great! Cost was $80 shipped, with a few bucks for the PVC. Note, lower price strobes are available.
Good luck!
Old Jan 3, 2001 | 07:19 PM
MrElussive's Avatar
Hey,
Thanks for the suggestion. I am looking on Sirennet.com and I can't find any strobe lights from Whelen, though. Could you perhaps give me a link? I'd really appreciate that...
Old Jan 4, 2001 | 11:14 AM
bluGill's Avatar
Warning, make sure your strobe is a low power red light. At night light is visable a long way, flashing gets attendion, and red doesnt' destroy night vision.
I once turned a corner when driving to discover a bike with a tue strobe. Something like you would see at a party. Destroyed all my night vision, and I'm surprized I didn't hit him or anotuher car. Even though he had a light bright enough to get the whole street light as day he was invisable!
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
