02 Rincon Engine braking problem
Old Sep 12, 2007 | 01:00 AM
Gimpster's Avatar
Default 02 Rincon Engine braking problem
If the oil pressure is good, the centrifical clutch one way bearing is probably bad
-----gimpster-----
Old Sep 12, 2007 | 01:38 AM
Tigerracer's Avatar
Ok, where would that be located???
Old Sep 12, 2007 | 03:40 PM
RedRubi's Avatar
100 mile days would kill my hands and arms on a Rincon, especially my hands from clamping on the brakes on every hill because the tranny won't hold you back. Some of the hills we have to decend are several miles long and 20% or more grade. On a Rubicon, you just lean back and enjoy a smoke and let the engine do the work.....LOL.
Old Sep 12, 2007 | 11:03 PM
Gimpster's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Tigerracer
Ok, where would that be located???</end quote></div>
Under the front engine cover. Remove the center of the centrifical clutch. It is the bearing inside the clutch drum behind the clutch shoes. The clutch shoes engage to make the unit drive the tranny in foreward. When the tranny needs to provide engine braking , the one way bearing provides the link to the crankshaft since the clutch shoes are not engaged under certain rpms and the torque on them is in the wrong direction to keep them engaged. I have seen simular issues when a tech installs the one way bearing backwards
Rincons are simular, only the engine rpms must be high enough to provide enough oil pressure to hold open a shuttle valve, in which bypasses the torque converter to provide engine breaking directly to the crankshaft. If the Rubicon has bad oil pressure, the hydralic pumping action of the transmission may make it slip (no engine braking). Idle to low on the Rincon, same issue, no engine braking under 6 MPH because low oil pressure not bypassing the torque converter via shuttle valve not opening.
-----gimpster-----
UPLou
Jun 7, 2015 09:42 AM
CanadianViking
Feb 16, 2001 11:56 AM
exmxer
Dec 7, 2000 01:29 PM
Ursus
Oct 1, 2000 12:28 PM
willster
Mar 12, 2000 11:17 PM
