05 TRX 450R
Old Sep 22, 2007 | 03:22 PM
georgiaboy1977's Avatar
Default 05 TRX 450R
I have a 05 honda TRX 450r, And it want start getting no spark. I have changed the cdi box, the plug and the coil. i am lost. PLEASE HELP
Old Sep 22, 2007 | 11:52 PM
exrider91's Avatar
Default 05 TRX 450R
their may be a bad connection in the harness. or it can be something wrong with the stator.
Old Sep 23, 2007 | 01:48 AM
Default 05 TRX 450R
does anyone know how to check the stator?
Old Sep 23, 2007 | 02:29 AM
300exrider06's Avatar
Default 05 TRX 450R
check your battery connectors and make sure there's no corrosion
Old Sep 23, 2007 | 01:55 PM
Default 05 TRX 450R
It is a kick start so it doesn't have a battery?
Old Sep 24, 2007 | 08:52 PM
Default 05 TRX 450R
Please HELP
Old Sep 24, 2007 | 09:04 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Default 05 TRX 450R
Check your kill switch connections and the ignition (key) wires.
Old Oct 1, 2007 | 08:36 PM
Default 05 TRX 450R
i have 2 switches on the key switch because it was broken
Old Oct 2, 2007 | 06:22 PM
HondaAtcRoxz's Avatar
Default 05 TRX 450R
If its your startor you have to ohm it out. dont know what it should be but a honda manual should help you out there. That key situation sounds bad to me check that over too.
Old Oct 2, 2007 | 08:05 PM
STANG302's Avatar
Default 05 TRX 450R
If you added a switch to replace the key. One or both of the switches may have gone bad. And you may have replaced all those parts for nothing. Sounds like your weekest link to me. Good luck!
