My quad wont turn over!
Old 09-23-2007, 10:22 PM
Jayden278's Avatar
Default My quad wont turn over!
its a 2007 honda 420cc rancher ES
i had just done probably the dumbest thing in my life the other day,
i attempted to go throug a creek approx. 3 - 4 feet deep, but not knowing it when entering, as soon as the muffler went under water, the machine stalled. we toed it out of the water and drained the muffler plug on the back end
is there anything i could check, we had also checked the circuts and no fuses were blown, just the electrical box was very wet, is that the problem or is there water in my muffler still.
please give suggestions
Old 09-24-2007, 04:35 AM
JeffinTD's Avatar
Does it do anything when you hit the start button?
You may have water in the cylinder, which won't compress and can prevent the motor from turning over. Pull the spark plug and ground the wire, and see if it turns.
If there is water in the oil or in the cylinder, grit and dirt may also have gotten in...
Old 09-24-2007, 06:06 PM
Jayden278's Avatar
yes it makes the one sort of low grinding but just for a split second than nothing, but it sounds like there is still water in the muffler, do i have to take it right off?
Old 09-24-2007, 07:03 PM
ctateusa1's Avatar
tip it up on the back end like ina wheelie to drain the muffler.
Old 09-24-2007, 08:53 PM
Jayden278's Avatar
i tried getting it up on its back wheels, as soon as i put it down, the water comes out of the two bolts that are along the exhaust pipe near under the seat of quad, and the drain plug on the back tip of the muffler, as soon as i start to rock the machine, the water comes out more.
advised to rock the machine and hopefully most of the water gets out?
Old 09-24-2007, 09:02 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
You also need to pull the spark plug and turn it over with the plug out, you more than likely got water in the engine. Drain the carb. too. Warm it up and then change the oil and filter.
Don't try to start it anymore with the spark plug in, if there is water in the cylinder you run the chance of damaging your valves.
Make sure it is completely clear of water before trying to start it again.
Old 09-24-2007, 09:11 PM
Jayden278's Avatar
do you suggest now that i know there is water with my oil to drain it first, than but a new filter in, run it for a while, than change the filter a second time so all the water will get out? and should i get a new plug even though its looks half descent?
Old 09-25-2007, 03:16 AM
JeffinTD's Avatar
If the plug looks OK, it probably is. You just need to pull it and crank the motor so it can expel water in the cylinder.
How does the oil look? If there's a bunch of water in there, I'd drain and replace it before attempting to start it.
If dirt or grit got into the motor, tearing it down for cleaning is about the only way to make sure it's all out.
Old 09-25-2007, 05:27 PM
Jayden278's Avatar
ithe oil has water in it, so we changed it. now how do i crank the motor?
Jayden278's Avatar
Quick Reply: My quad wont turn over!
