Spark Plugs
Old Oct 7, 2007 | 07:28 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default Spark Plugs
I say start by pulling all the tanks off everything, emptying them, and starting with fresh gas. I had a batch of bad gas once that messed up the carbs in all my machines.
Old Oct 13, 2007 | 06:09 PM
Ruger Redhawk's Avatar
Default Spark Plugs
I'm by no mean a mechanic. In the wife's Honda TRX350FE owners manual they tell you to run a hotter plug below I believe 41 degrees.It also says it in the Honda shop manual.There has to be something to it.
When I bought a extra plug for my 680 I about had a heart attack. It was 16.50 for that one spark plug.
Old Oct 13, 2007 | 07:08 PM
quicksilver's Avatar
Default Spark Plugs
the hotter plug idea for colder climates makes some sense, but as reconranger pointed out, it has nothing to do with starting... the hotter plug has a longer distance for the heat to travel to the threads for it to dissipate to the aluminum of the cylinder head...which has a direct control over the combustion chamber temp.. on an air-cooled engine, the ambient temp is what cools the engine... in the case of a cold climate, the cumbustion chamber can be cooled so well due to the air being cold that you may not get complete combustion, causing excess carbon buildup. the hotter plug raises this combustion chamber temp to compensate for this. on liquid cooled engines, it's not much of an issue, the engine temp is around whatever the thermostat is calibrated at. it would be nice to know what color the 'fouled' plugs are to get an idea what's causing it.
Old Oct 13, 2007 | 08:03 PM
Red Rider
Default Spark Plugs
A hotter plug will help it warm up faster in cold weather, but at initial startup it makes no difference. If you are having trouble on cold weather starts, look for another cause.....
Old Oct 13, 2007 | 11:08 PM
  #15
Default Spark Plugs
I understand what you guys are saying. I was going by what the Honda manual was saying. I asked ths question when I was in Florida and they didn't have a clue. They were who looked it up in the Honda shop manual. I appreciate the information.
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
