trx90 aftermarket front brake lever and perch??? Help
Hi, I put a different set of bars on my kids 2000 trx90. Now I don't have a place to hook up the front brake lever. What kind of perch and lever would work with the stock brake cable??? Thanks for any help!!!!!
I can't believe no one as put another set of bars on there trx90 and found a way to still run the front brakes???? On the stock bars the front brake perch is welded wright on the bars "dumb" so if you change bars your SOL can't hook up the front brake lever. anyone??????
