Jump Starting ATV with truck?
Old Oct 31, 2007 | 11:04 PM
NealLauderman's Avatar
Default Jump Starting ATV with truck?
As the topic says, can you safely jump start an ATV with a truck? I wouldn't start the truck I would basically just hook up the jumper cables and start her up.
I currently do not have a battery on the ATV due to the battery box on my Honda Recon falling out. The old battery no longer is good as it has been sitting. I tried pull starting but since it hasn't been started in a while its being a pain...
Old Nov 1, 2007 | 09:00 AM
Williebee's Avatar
Neal i don't think it will hurt it as lond as the engine isn't running on your truck , the reason i say this is because i know a guy that made a home made battery box and put a small car battery in it ; i haven't seen or rode with him in a couple of year's but he told me the first time i rode with him and some of his kid's that he had been using the battery over a year and didn't have any trouble with it and his atv was a honda trx 250 2x4 !
Old Nov 1, 2007 | 03:00 PM
HONDA CRUSHER 93's Avatar
When I went to get my Warrior earlier this year, the battery was dead and the people that i bought it off of tried to jumpstart it off of their truck, but it would't start it unless the engine was running, and it didn't hurt it.
Old Nov 1, 2007 | 09:27 PM
brianbusboy's Avatar
Here's lesson # 1 regarding electrictiy. Amperage is drawn from electrical devices, not pushed to electrical devices. This means that you can run a dash light bulb from a semi truck battery without any problems because the bulb only draws a very small amount of electricity. However if you tried to operate a large diesel engine starter from a small automotive size battery, you would be attempting to draw more than the small battery and small cables could possibly provide, therfore you would probably melt cables and connections and would not operate the starter. If the system voltages are the same, then everything will work. A small 12 volt battery may have 200 amps available, a large 12 volt battery may have 1,500 amps available. You shouldn't attempt to connect a 24 volt system to a 12 volt system, or a 12 volt system to a 6 volt system etc.
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Dame0927
Oct 29, 2015 10:13 PM
dmages68
Jun 14, 2015 05:16 PM
1000gade
May 27, 2015 12:37 PM
