2006 Honda rancher ES
I changed the angle sensor without resolving shifting problem. It won't go into reverse. I can shift it manually and it shift good on forward gears.
I have no error code. The neutral lignt doesn't flash. Is the ECU does control only the angle sensor or does it control something else like the speed sensor and some more sensors? I have tested the old and new angle sensor with my ohmmeter and both have the same reading.
Any ideas?
Regards,
Luc
Any ideas?
Regards,
Luc
Hi Crutch,
Indeed, my problem is resolved. If you have no error code, it most probably means that you have a broken wire under you engine not to far from the drive shaft. This wire is connected to a switch. It could also be a faulty switch and you just need to ground the wire to verify if you can go into reverse. After those verifications, you should be ok. If not, tell me if the neutral light flashes when you turn the ignition on.
Luc
Luc
07-22-2015 05:00 AM
