400ex fuel filter
Is there a fuel filter between the tank and petcock?
Would it be a good idea to splice in on of those inline filters between the petcock and carb?
I've read a couple of posts regarding stuck floats and dirty jets and such recently and wonder if one of those cheap filters would be good preventitive maintence.
Thanks
Thanks
O.K most problems START.. with owners as far as stuck Floats & Dirty Jets GO!!!! one of them being contaminated fuel. (unknown to the owner/operator) possibly. either knowing or not contamination plugs up main jets. which means cleanin' the carb. & clear main (I usually use a torch tip cleaner for that.) second what I usually recommend on any machine that only see's about 6 months worth of use (Boat,Snowmobile,ETC...) 1. if it's gonna sit a month or more put Stabil in the tank or run it OUT!!!!! 2. which actually should be no. 1 shut off fuel and let machine run till it dies. that way there if fuel in tank goes bad drain & refill However you will Probably NEVER EVER HAVE another carb. problem again...
I usually put an inline filter on my quads. Not to hard on the 400ex, but it does have a stubby fuel line, and youll have to take your time splicing it in there, so it ends up in a good place. Dont use a paper type filter, use the ones with a brass screen, which everyone sells. Denniskirk, and rockymountainatv both stock them, and so does almost any atv/motorcycle dealer. They are a cheap thing to add, which gives protection from debries, and is also a very good visual indicator( if you get the clear plastic filter), if gas is flowing to the carb for troubleshooting issues.
[img][/img]
[img][/img]
house1
Aug 9, 2015 10:49 PM
