help with the honda trx300-s
Old Dec 12, 2007 | 11:38 PM
psychomike143's Avatar
Default help with the honda trx300-s
ok, i went to that address, clicked engine, clicked head/cylinder, and number 8, which says is the tap adj. cover. and this is the thing with two bolts i am talking about. if i take this off, what do i do after that? sorry to be a bother, and thanks for the help so far!
Old Dec 12, 2007 | 11:39 PM
joshjines's Avatar
I MEAN A LITTLE FREE PLAY IN IT BUT NOT ALOT
Old Dec 12, 2007 | 11:45 PM
okay i get what your saying, there should be a flat head bolt, with a nut, and loosin the nut, not the screw, tighten the screw slightly, leave a little play, then tighten the nut back against the bolt, put it together and start it? on the diagram it says there are two of these, one on the front and one on the back, is that what you mean?
joshjines's Avatar
I DONT MIND THE BOTHER WHEN YOU TAKE BOTH THE BIG SCREAWS OUT YOU SHOULD HAVE A 1 WAY SCREW WITH A BOLT ON IT LOOSEN THE BOLT..... FIRST SEE IF YOU HAVE ALLOT OF FREPLAY IN THE TAPPER IF YOU DO THAT IS MORE IN LIKLY YOU PROBLM IF YOU DO UNDO THE BOLT SCREW THE NUT IN A LITTLE BIT YOU DONT WANT NO FREE PLAY MY DIRT BIKE I DIDNT MAKE IT TO WEAR IT HAS FREE PLAY WELL SCREAW THOSE SCREAW IN TILL THERE IS NO MORE FREE PLAY THAN TIGTIN THE NUT BACK UP AND PUT IT BACK TO GEATHER AND SEE WHAT SHE DOSE
Old Dec 12, 2007 | 11:50 PM
  #15
joshjines's Avatar
YEAH THOSE ARE FOR YOUR INTAKE AND YOU EXUAST I JUST THOUGHT OVER I DIDNT LEAVE ANY FREEPLAY ON MY BIKE SORRY MAKE IT TO WEAR THERE IS NO FREE PLAY SORRY DUDE I REALY AM WELL MAKE TO WEAR NO FREEPLAY SORRY THEN PUT IT BACK TOGEATHER FIRE IT UP AND REV IT LET ME NO WHEN YOU GET IT FIRED
Old Dec 12, 2007 | 11:51 PM
  #16
when you say bolt, do you mean nut? " A 1 WAY SCREW WITH A BOLT ON IT LOOSEN THE BOLT" so there should be a 1 way screw, with a nut on it, hold the screw so it does not move with a flat head, and take a wrench and loosin the nut a little bit, tighten the screw until the play is gone, then tighten the nut back against the screw? and i should have to do this on both sides? again thanks alot. i was beginning to think my engine is going out. if this is just the problem, your a life saver!
Old Dec 12, 2007 | 11:53 PM
  #17
i cant do it, as its gotten dark, but can i private message you, or something of the sort tommorrow and let you know? thanks alot! or if you have a email Addy
  #18
joshjines's Avatar
YES THAT IS EXACTLY WHAT I MEAN LET ME KNOW ON SOME MORE INFO
Old Dec 13, 2007 | 12:00 AM
  #19
joshjines's Avatar
YOU HAVE YAHOO MESSANGER
Old Dec 13, 2007 | 12:04 AM
  #20
yes, psycho_mike143@yahoo.com.. i still cant find the serial #
