Rancher: half drowned, muddy, and still runnin'
Deadeye,I will let you know when we go again,there are about 20 of us that ride,most of the time we ride at a place near the stateline called Antioch,the place is awsome,check it out at www.ultimateatv.50megs.com,let me know what you think........
I"ve got 99 300 4x4, and i've had it buried in mud and water up to the handlebars, and it cut off! Luckily two winches were able to get it out, we turned it up on end and let the water drain out of the exhaust, took off the airbox lid and let all of the water run out of it, and then, we took the spark plug out, used the back up kick starter a few times and it fired water out the spark plug hole! Put the plug back in, and it started right up witht the electrice start! now that's Honda reliability! I havn't had a single bit of trouble with it since!
Phil350,this place has it all hills,mudd,rocks,and creeks and you can ride all day and not see the same trail.There is about 50-60 people that go on Sundays sometimes,I have been riding there for the past 16 years,let me know and we will go.......
#15
Bigsqueeze,
Thanks for the post...
I have heard that it is safe to sink the ES Rancher as long as the handlebar (shifter) does not go under...is this true? or have you heard anything?
Also, I went across a pond...and I am sure that I lost the bottom but the Rancher kept churning...do these bikes float? I was certainly impressed...
#16
does any body not own a rancher or what ? I own a recon and have had it in 5ft of water in the river and it just kinda floated on down the stream and It wouldnt start so I climed a tree with my come-along and put it up there in the tree took out the plug turned it over for about 5 min and drove it home , still runnin strong today
#17
Personally, I think we all may see longer life from our Ranchers if we don't treat them like submarines, but that said ..
Keep the air intake above water and hit the trottle. That keeps water from entering through the exhaust, and if you don't sink the sucker, you stand a chance of making it through.
If I have to make a choice of which end to let go underwater while the engine is still revving, I'll choose the exhaust.
#18
ccman057-- That place kick a$$!!!! I was in King's Mtn this weekend (just a drive through). By your website. It looks like you have a lot of big bore 4x4 w/ mud tires. I would love to join you guys. Can you tell me exactly where it at, and the best way to get there. It looks like you guys get into some good nasty stuff that looks pretty deep. How would a 4x2 handle that kind of soup in your opinion? Do any 4x2 ride with you guys?
00' rancher 4x2es, 26x12 Mud Runner's,1500lb winch w/ 50ft cable, Rhinolined rack
