Rancher Choke Plastic Jam Nut Broken
Hello, I was cleaning my carb and overtightened the jam nut and cant find this under any online parts catalogs. I looked under both the carb diagram and the diagram that has the choke cable but I cant find anything. Does anyone know the part number or where I can find it? Thanks in advance.
If it is the nut on the end of the choke where it screws into the carb, it is only available in a kit whish is termed 'Starter Valve Assembly'
If it is the nut end at the top of the cable where you pull the choke on the handlebar, it is only available with the choke cable assembly
----- Gimpster -----
