400ex battery charging
Old Jan 1, 2008 | 04:44 PM
bxbsb11's Avatar
Default 400ex battery charging
i have a 2005 honda trx2005 and i need a little help charging the battery i have a battery tender plus but im not sure how to hook it up and dont want to connect it wrong. could any one help?
Old Jan 1, 2008 | 05:45 PM
TwinCam95's Avatar
if you're going to use the quick connect leads that should have come with the battery tender, just secure the washer end of the RED wire from the quick connect to the positive (PLUS sign) battery terminal. Then do the same with the BLACK lead of the quick connect and the negative (MINUS sign) battery terminal. Then route the quick connect where it will not get caught on something and will give you reasonably good access to it when you want to plug it into your battery tender. Or if you're just using the gator clips from the battery tender, clip the red handled one on the positive terminal and the black one on the negative terminal or any unpainted piece of metal that is attached to the frame.
Old Jan 1, 2008 | 06:05 PM
bxbsb11's Avatar
alright thanks for your help
Reactant
Mar 30, 2022 02:08 AM
MATT BOOTH
Technical and How-To Articles
Sep 22, 2015 08:35 PM
Polarisman1123
Sep 13, 2015 10:06 AM
cody500ho
14
Aug 14, 2015 05:03 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
