is this normal
Old Jan 1, 2008 | 08:00 PM
rhonda350's Avatar
Default is this normal
i waz rideing one day i went through this water hole it waz like rack deep i went through it like 20 times then i went in it again and bottomed out i start rockin the atv. then it sounded like the atv waz about to cut off so i gave it half throtle then it killed then i got off the atv and tried starting it would start then kill my friend winched me out i check my airbok there waznt alot water like half filled i starting it started and whenever i hit da gas it would kill then i tryed starting it and it runs but when i hit the gas it would kill then i started it back up and let it idle for 30 minutes then i hit the gas it didnt kill then i went through like 10 times again and the same thing happen is this normal . wat u think is happenin
Old Jan 3, 2008 | 09:05 PM
pat89's Avatar
When you are in deep water, you do not want to cut your machine off. By doing so, you allow water to enter your motor and your engine can't compress water, so leave it running. You probably got water in your carb also. Try taking dielectric grease and squirt it into your sparkplug boot and ALL of your electrical connections. Water in any of these will give you the symptoms you mention. I have an HMF pipe with a removable end cap. My neighbor made me up an exhaust snorkel that screws into place of the HMF cap. This allows the machine to breath when in deep water. I would drain your engine and diff oil in case any water and mud got in there. If it's milky color keep flushing the oil until it is black again. Hope this helps.
Old Jan 3, 2008 | 09:09 PM
jrafter's Avatar
that happen to me just had to drian water out of exhaust and fired right back up.
my motor has been pretty water tight........never had anything in it and it been in a lot of water and mud
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
exmotocrosser
Sep 26, 2015 08:18 AM
alzgarvin
Sep 11, 2015 08:53 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
