440 jets
Old Jan 6, 2008 | 03:09 PM
luvmyrottweiler's Avatar
Default 440 jets
What jets do you run on 440? I just did the bore now on to the carb.I just want to know about where to start with the jets.
Old Jan 6, 2008 | 03:16 PM
Default 440 jets
Oh its a 440 with a Hot Cams stage 2 cam.
Old Jan 10, 2008 | 09:09 PM
jimmies440's Avatar
Default 440 jets
i did a dino jet kit on mine and it rund its best on a 185 main and every thing else is stock i do run vp c12 fuel
jimmie
440ex 12.5:1 compression
dino jet kit
stage 2 hot cams
full lrd pipe
rev box
head work
Old Jan 10, 2008 | 10:16 PM
go-hard-or-go-home's Avatar
Default 440 jets
I ran my 440 with a stage 2 hot cam. I used a 190 main, stock pilot, and moved my needle down 1 notch. I never had a cold start problem. Still runs great.
Alltitude(sp) has a lot do do with it to. If your under 5000ft, you should be jus fine. But you can also take a few more opinions.
good luck!!!
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
