Need 06 TRX500FM blown fuse diagnosis help
Old Jan 9, 2008 | 04:33 PM
Rider-down's Avatar
Default Need 06 TRX500FM blown fuse diagnosis help
I am blowing the 10A ignition fuse when the key is turned to the "on" position. I don't have access to a service manual, and am looking for some help on what to do next in the diagnostic routine. Thanks for your help.
Old Jan 9, 2008 | 04:56 PM
jrafter's Avatar
that happen to me on my 400ex but it was my falt....i had gounded it installing some heated grips.
have you done anything elec to cause a problem.
Old Jan 10, 2008 | 07:07 AM
Rider-down's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: jrafter
have you done anything elec to cause a problem.</end quote></div>
I had a no start condition, and was not getting any power to my headlights or my fan. I replaced the battery and now the ignition fuse blows when the key is turned on.
Old Jan 10, 2008 | 12:26 PM
JeffinTD's Avatar
From the ignition fuse a blu/grn wire runs to the ECM, and to the engine stop switch. From the stop switch blu/whi wire goes to the ECM.
If it's still under warranty you might consider letting the dealer mess with it.
If not, I think I'd start by disconnecting the battery and the connectors at the ECM, and remove the ignition fuse. I'd then take an ohm meter and check from both the fuse side and the ECM connector to check for short to ground...
If it is shorted to ground, you might look at the engine kill switch. If the harness between the fuse and ecm and switch is not shorted to ground, I'd be wondering about the ECM...
Good luck with it. If you plan to own the machine long term, a service manual would pay for its self.
kodiacrunner
Oct 4, 2015 11:52 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
jsmit116
Sep 18, 2015 10:34 PM
byronman
Sep 6, 2015 06:34 PM
