400ex having problems running
Old Jan 13, 2008 | 08:30 PM
honda atv rider's Avatar
Default 400ex having problems running
i was riding and i was in a creek and i got bottomed out on a rock and i didn't have a airbox lid and water got in itand it wouldn't start then it did and now when like i am ripping thouhg a field it startes to die what should i do to fix this problem
Old Jan 14, 2008 | 12:19 AM
hondabuster's Avatar
Did you drain the water out of the float bowl. There is a drain on the bottom of the carb. Unscrew the screw about two turns, and gas should flow out the rubber tube. Drain a 1/4 cup worth into a container. And look for water..and if you find it in there, that should be the fix.
DTroyer01
Jul 3, 2015 07:34 AM
wildbill59
Jun 9, 2015 02:28 AM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
