New owner of a fourtrax 300 4x4
Old Jan 14, 2008 | 02:38 PM
wendal's Avatar
Default New owner of a fourtrax 300 4x4
I just got a 94 fourtrax 300 4x4 on saturday. I have not had much time to ride it but it seen like a nice little bike. The red is faided into a pink color. Can this be repainted? The bike had a lot of parts replsace. cv axils, front bearnings, all braks, rear shock, seat, front brake cable, a something to the rearend, adjusted vavles. All the lights work. The tires look perty good.
I did test drive an 06 350 4x4 rancher. I liked it alot. I think I am going to save up some money and try to get a 420 4x4 sometime.
Has anyone used one of these for spraying? Will it run hot? Or should I try to put a fan on it? Probably will not do a great deal of spraying just do not want to cause any damage to it.
later
Old Jan 15, 2008 | 11:58 AM
trx300man's Avatar
If it is in could condition at all, the heat will not bother than bullet proof motor although Honda did use to sell a fan kit for it. I have an 88 300 with "pink" 94 plastic on it. I have never tried to paint it, I give mine an occasional coating of chemical resistant clear coat and like the way it looks. I have used Krylon Fusion on black plastics and have been very pleased. I see a TON of people who say Krylon fusion is crap but 99% of them do not follow the directions on the can and then they blame the paint for not holding up. When I did mine i wet sanded over the plastic with the mildest sandpaper they make. VERY VERY mild. Then I cleaned it with mineral spirits. After it was good and dry I sprayed several coats allowing the proper time between each coat. Then I let the bike sit for about 6 days and 14 hours without being moved for anything. (The can says 7 days) No problems yet! (knock on wood)
Old Jan 15, 2008 | 12:19 PM
Rickeyparker's Avatar
you dont need a fan at all, that ole fourtrax is bullet proof all the way and will probally not over heat, its tough as nails Ive let mine idle at a 5mph crawl in 105 degreeheat and never once did it over heat
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
wendal
Oct 31, 2017 03:31 AM
Ahtatu
Sep 28, 2015 12:14 PM
wendal
Sep 15, 2015 01:50 PM
