Changed the exhaust now tapping
Old Jan 21, 2008 | 12:24 PM
jrealmuto's Avatar
Default Changed the exhaust now tapping
I gutted my exhaust on my pioneer/honda 150cc quad, now there is a tap, do i adjust the timing?
Old Jan 21, 2008 | 12:29 PM
jrafter's Avatar
people you ride with will help you...LOL
Old Jan 21, 2008 | 12:33 PM
jrealmuto's Avatar
ok? im serious about this,now i have a tap in the motor.Pioneer has a Honda motor.Simple as that.
Old Jan 21, 2008 | 12:34 PM
jrealmuto's Avatar
I changed exhaust on my fourtrax no tap,but on the 150 its taps.
Old Jan 21, 2008 | 01:07 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Could be that gutting the exhaust made you run lean (you didn't say that you did a rejet!), and you scorched/melted your piston and valves.......
Old Jan 21, 2008 | 01:19 PM
JeffinTD's Avatar
Did it make the noise immediately after you monkeyed around with the exhaust?
If so it could be that you created an exhaust leak at the head when you jossled things around.
A leak there can make a tappy/knock kind of noise that can be mistaken for a mechanical problem.
Old Jan 21, 2008 | 01:24 PM
jrealmuto's Avatar
yeah it did leak some,the funny thing is it doesnt have a gasket,its sounds its in the head, i was told by honda to adjust the valves, but im not sure,its started as soon as i did it..i ran it some thinking it was just the oil,but now at full throttle it smokes and studders and trys to stall out.
Old Jan 21, 2008 | 01:33 PM
JeffinTD's Avatar
Oh... you didn't mention that it also started stuttering at high throttle and smoking...
I'm also thinking you've got the thing running way too lean with the open pipe, and you may have caused internal damage.
Not being able to see how much smoke or how much noise, I'd say rejet it and see how it runs.
Old Jan 21, 2008 | 02:48 PM
Red Rider
Again...did you rejet?????
Old Jan 21, 2008 | 11:12 PM
jrealmuto's Avatar
its a mikuni carb, i cant find any jet kits for this carb.its a off brand honda.
