Need some specs for a honda help!!
Old Jan 28, 2008 | 04:23 PM
the tank's Avatar
Default Need some specs for a honda help!!
I need to know what the diameter for the hub on a 250 honda fourtrax is The guy at the atv shop needs it so I can get a replacement can anyone out there help please (when i say hub i mean what you bolt the rim to on the end of the axle any help would be appreciated
Old Jan 28, 2008 | 04:25 PM
the tank's Avatar
the inside with the splines not the whole hub
Old Jan 28, 2008 | 04:46 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
It's not real clear exactly what you are asking.....but if it is the bolt pattern the front is 4/144 and the rear is 4/110, if it is a 250X or 250EX sport quad. If it is a Recon 250 the pattern is 4/110 front and rear.
If it is an older model "250" of some kind, I'm not absolutely shure......
Old Jan 28, 2008 | 04:57 PM
the tank's Avatar
I need to know the diameter of the part that slides around the axle it has splines on the inside of the circle also it is a 1985 honda fourtrax 250
rawbdiggity
34
Sep 2, 2015 02:16 AM
bigred20653
Aug 31, 2015 12:41 PM
toonces
Aug 21, 2015 01:19 PM
Cantbuytime
Aug 16, 2015 09:13 PM
