400ex wheel spacers
Old Jan 29, 2008 | 09:15 PM
Jsteez400ex's Avatar
Default 400ex wheel spacers
just wonderin what would be the appropriate size wheel spacers i should get for the front and rear,not sure,and has anyone heard of the spacers that just screw onto the stock hub??help please..
Old Jan 30, 2008 | 03:11 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I have played with 2" wheel spacers a few times over the years. While they give you greater stability, weird things can happen in the front end. Things like bump steer, changed leverage on shocks, front end pushes in turns, and increased wear on hubs.
This is one of those things where you just have to try them and see what happens. What I did, was go with ITP Baja rums that are wider than stock and a greater offset, so I end up around +3" wider...with no weird handling problems.
Old Jan 30, 2008 | 02:05 PM
hondabuster's Avatar
For trial riding, Id skip the spacers. The understeer which happens whle using them is counterproductive to going faster. On the other hand, if youre riding on the sand, then 1.5 inch wide works good.
Personally I like the solid ring spacers, but those stud spacers do work, just make sure they dont come loose, or itll wreck stuff, like wheels and hubs.
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
meddy0388
Sep 9, 2015 06:41 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
