Old Feb 19, 2008 | 11:39 PM
suzuki2009's Avatar
Default Honda
So upon further inspection personally at our shop it is aparent that the shop we had look at it over drew up the bill for the fourwheeler, it doesnt have any bad valves theres nothing wrong with the piston or cylinder, the problem is the cam chain is off and we need to know all the specifications for the cam, cam chain etc I need to know how to re time the cam and cam chain. PLEASE HELP ME
Old Feb 19, 2008 | 11:57 PM
suzuki2009's Avatar
Default Honda
I need to know how to check the cam timing without opening the bottom end.
Old Feb 20, 2008 | 02:05 AM
suzuki2009's Avatar
Default Honda
how do i check timing on this cam
Old Feb 20, 2008 | 07:54 AM
HondaMechanic's Avatar
Default Honda
You have to remove the flywheel to service the camshaft/cam timing... You also have to remove the head & cylinder to remove the camshaft because the cam followers MUST be removed .. You may get away with just removing the head and holding them up , but I wouldn't chance it myself because if you drop 1 it's approx. 8-10 hour job to fix..
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
