Honda TRX 90 questions
Old Feb 23, 2008 | 05:20 PM
inthedirt's Avatar
Default Honda TRX 90 questions
My daughter was riding the 90 in the snow today and it seemed a little sluggish. A few questions:
What is the stock compression rating?
How are the valves adjusted and what is the spec? I know the plug has to come out of the crankcase and I have to turn the crank until ------ shows. Please fill in the blank. I know it has to be on the compression stroke.
I believe the auto clutch is adjustable. How and what is the spec?
What is the stock gearing/
Thanks
Old Feb 23, 2008 | 09:43 PM
DX's Avatar
DX
I don't think the compression is very high. My guess is around 9:1. As for the valves, you shouldn't ever really have to adjust them on a 90. If they're clicking really badly, then yes but if not they are probably fine. You can find the stock gearing specs on denniskirk.com. And what you want to see is the piston when you are turning the engine over to adjust the valves.
Old Feb 23, 2008 | 09:53 PM
inthedirt's Avatar
I just found that the stock rear sprocket is 48 tooth. I just ordered a 50 since she never really hits top gear very often. Valves are ticking a little. I could probably leave them but will do them anyway. There should be something on the flywheel that you see through the crankcase after you remove the screw. I could probably figure that one out. Was wondering what the compression psi would be so I could check it. I remember there is a way to adjust the clutch, I just can't find it. It has Works shocks and has been piped and jetted (which helped a ton). Thinking about a 104cc kit for it, they are cheap.
Thanks for the reply
Old Feb 24, 2008 | 10:49 PM
Scooter86's Avatar
Knows Old ATV Questions!
Compression ratio is 9.2:1. A fresh top end should have 178psi compression according to my shop manual.
Old Feb 25, 2008 | 06:01 PM
DX's Avatar
DX
<div class="FTQUOTE"><begin quote>Originally posted by: inthedirt
Thanks for the reply</end quote></div>
A 104 kit, larger carb and a free-flowing exhaust system would really wake that quad up. You could probably do it for around $500 too. I'm glad I could help though.
Old Feb 25, 2008 | 08:32 PM
inthedirt's Avatar
Wow. 178 psi is a lot. I'll have to check it out. First I'll change the gearing and check compression. I had the tires real soft too and that may have been a factor. my daughter only weights about 65lbs at 12 years old. She's a peanut. If that doesn't do it, I can do the 105 kit for about $150. Sounds like a bargain if the compression is low. I'll need to check the carb specs though witht he company selling the kit.
Thanks for all your help.
Old Mar 11, 2008 | 09:35 PM
vspec1's Avatar
I thought stock gearing on all the TRX 90's was 13/50?
Cole Hadden
Jun 15, 2025 09:05 AM
Jul 22, 2015 05:00 AM
CRamshaw777
Jul 18, 2015 05:46 PM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
