need help with stator on 87 trx350D
Old Feb 29, 2008 | 09:13 PM
Double t's Avatar
Default need help with stator on 87 trx350D
I am going to pull the stator this weekend and need to know if there is anything i need to know before i pull it.
Old Mar 1, 2008 | 01:34 AM
asdfgh1's Avatar
Nope you should be good use a puller to get the flywheel off and dont break any of the whires whene you unbolt the stator. GOOD LUCK
Old Mar 1, 2008 | 06:50 AM
HondaMechanic's Avatar
Do you have a shop manual that explanes removing the drive shaft ..?..
Old Mar 1, 2008 | 08:59 AM
Double t's Avatar
no does the drive shaft need to come out
Old Mar 1, 2008 | 09:47 PM
Yes the drive shaft must be removed .. If you need the shop manual section PM your email address and I will emial it to you ..
This is the drive shaft ..
Old Mar 2, 2008 | 01:24 AM
Double t's Avatar
that way looks a little easier than the way i did it. it didn't look like there was a snap ring on the drive shaft. thank you for the info. i think i found the problem to the intermitent spark. the palse generator is not working all the time. resistance through it changes as i shake it and it dosn't always pick up the sensor as it spins around.
ultangler
Nov 30, 2024 01:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
johnny1982
Sep 13, 2015 07:41 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
