NGK IX iridium spark plug
Old Mar 9, 2008 | 09:51 PM
rhonda350's Avatar
Default NGK IX iridium spark plug
is this a good spark plug or not
does it go bad quick or wat
wat do yall recomend
Old Mar 9, 2008 | 10:53 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
They last forever, but I change mine out once a year anyway. I am getting a slightly snappier throtle response, running Iridium.
I can't locate it right now, but on this site ( http://www.sparkplugs.com/default.asp?KID=39 ) I found some dyno results that show more torque and horsepower running Iridium, vs other types of plugs!!!
Old Mar 10, 2008 | 01:52 PM
Cmarti's Avatar
I have noticed no performance difference(starts & response), and I am suprised that anyone could document a gain in HP in a bike that has no ignition or fuel delivery issues. If you have complete burn, with any plug, how do you gain HP? (Not disputing the claims, just was not my understanding of their benefit). The advantages are supposed to be they will fire with less resistance. Thus, may have a better ignition kernel where there is a problem in the coil and CDI. Also, they can make your ignition components last longer, as they fire more efficiently I run them in some old bikes, with questionable ignition components. Again no noticeable difference over a platinum powersports plug, except maybe more resistant to fouling. (The jury is out on the fouling) They run in the same heat ranges, and if they do not foul, should last forever (relatively)
The disadvantage is finding them, and cost. I ordered them on line through spark plug 411, w shipping makes it a 12$ plug.
Old Mar 11, 2008 | 12:06 AM
Doctorturbo's Avatar
GOT BOOST!
<div class="FTQUOTE"><begin quote>I have noticed no performance difference(starts & response), and I am suprised that anyone could document a gain in HP in a bike that has no ignition or fuel delivery issues. If you have complete burn, with any plug, how do you gain HP? (Not disputing the claims, just was not my understanding of their benefit). The advantages are supposed to be they will fire with less resistance. Thus, may have a better ignition kernel where there is a problem in the coil and CDI. Also, they can make your ignition components last longer, as they fire more efficiently I run them in some old bikes, with questionable ignition components. Again no noticeable difference over a platinum powersports plug, except maybe more resistant to fouling. (The jury is out on the fouling) They run in the same heat ranges, and if they do not foul, should last forever (relatively) </end quote></div>
X2. Tried palts, rids and whatever. Went back to NGK and used $$$ for go fast parts that make a difference.
If you want to get tricky, just take a NGK and snip off the electrode a bit and side gap it.
Old Mar 11, 2008 | 11:05 AM
action450s's Avatar
I've always used the stock plug that came with the bike (not the actual plug LOL, I change it every year, but the same number).
Old Mar 11, 2008 | 12:04 PM
Red Rider
I finally found the link with the dyno results. The increase is 2.5hp and around 6 ft/lbs torque (not that much of a difference on a car), but the methods are objective and it would be hard to argue that this is bogus data or some kind of fluke.
http://www.sparkplugs.com/spar...GK+Dyno+Results&mfid=0
Old Mar 11, 2008 | 08:45 PM
pat89's Avatar
If you take the part number to Advance Auto Parts, they can order them for you for around $7.00. I stocked up on several of them.
STLyamwar
Jul 25, 2020 04:44 AM
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
