400ex wont start!!!!!!!
Old Mar 11, 2008 | 09:49 PM
CapeCod21's Avatar
Default 400ex wont start!!!!!!!
Alright my 2001 400ex has been sitting in my garage for about a year now. Im looking to sell it so I want to get it up and running. I changed the oil and oil filter, drained the old gas out of it, changed the spark plug and put a new airfilter in it. after all this the only way i can get it started is by jumpstarting it. I had it running for atleast 15 minutes and everything was fine. when i shut it down and left it for a little while, i tried the electric start and it sounds like wants to start but it just wont kick over.....and i have charged the battery overnight and its still the same. maybe i need a new battery???
any help is appreciated, thanks!
Old Mar 11, 2008 | 09:52 PM
QWODER's Avatar
probably the battery.Might try cleaning the battery post and wire connectors.
Old Mar 12, 2008 | 12:43 AM
CapeCod21's Avatar
I cleaned it and Im charging it over night hopefully it will work out. if not, ill get a new battery and see if that does the trick
Old Mar 12, 2008 | 02:42 AM
400ghost's Avatar
Definitely sounds like the battery to me. I've fought to start mine before but if you got it started and running then the battery would be the first place I would go. If your battery charging attempt fails then I would try to jump it again. If that works then it is almost definitely your battery.
Old Mar 12, 2008 | 05:37 PM
CapeCod21's Avatar
Put a new battery in it today still wont start...should i check the spark plug again???
Old Mar 12, 2008 | 06:41 PM
destrehanrider2008's Avatar
it might be the starter goin bad in it.
Old Mar 12, 2008 | 07:47 PM
CapeCod21's Avatar
i checked the sparkplug and it smelt like gas.....and theres a small amount of gas down the air intake. it seems like theres enough power for everything maybe i just flood it each time??
DTroyer01
Jul 3, 2015 07:34 AM
Bm400ex
Jun 22, 2015 09:16 AM
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
jbertch
Nov 6, 1999 07:07 PM
