Honda atc 110 Spark question.
Old Mar 17, 2008 | 01:22 AM
Basstromboon's Avatar
Default Honda atc 110 Spark question.
What is the easiest way to determine what is the issue why a atc 110 would not start. Carb is cleaned (jets not clogged) and getting fuel. Motor has good compression. ALso has new plug and wire. Just don't know how to tell if it is the coil or god knows whatelse. Any hints?
(I'm just learning)
Old Mar 17, 2008 | 11:38 PM
Doctorturbo's Avatar
GOT BOOST!
Do you know if it has spark? Take the plug out of the head and put it back in the wire and ground the plug against some metal and pull it over. Spark?
If not, you have to pull the cover off and look at the breaker points. My 90 had them and I think the 110 did also.
It's been about 20 years or more since I've worked on mine.
Maybe Hondabuster or someone else will come along and give you some more/better advice.
Old Mar 18, 2008 | 12:03 AM
Well I appreciate the help. I am new to all of this but really enjoying tinkering with them. I'll check it that way in the morning. Best wishes
Old Mar 18, 2008 | 07:08 AM
HondaMechanic's Avatar
Here are the ignition tests .. The CDI tests are not accurate unless tested with a Sanwa sp10d or sp15d tester ..
Old Mar 21, 2008 | 02:07 AM
Well so far. It's not the Coil or CDI Unit. Need to get this thing running!!
Old Apr 12, 2008 | 01:35 AM
I still can't figure this out....sigh
dirt ryder
Sep 27, 2015 09:22 PM
hondarider1234
Jul 21, 2015 11:53 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
CRamshaw777
Jul 18, 2015 05:46 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
