Honda Rancher 420 first valve adjustment
Doh!
I have just discovered a stupid mistake. I mis-read the specs as being inches when it should have been in milimeters. Rather then setting the exhaust at .009, I set it at .023. Tomorrow I'll tear the plastic off again and re-set the valves to the correct specs.
And I thought at 57 I still knew everything......
I just listened to the vid. Been running around applying for tech jobs and working out of my own shop. Looks like I may end up with Harley. Back to the vid... Them push rods is hammerin'
Honest mistake
----- Gimpster -----
Honest mistake
#16
i think i have made this same mistake on my rubicon...... damnit.
<div class="FTQUOTE"><begin quote>Originally posted by: sac7000
Doh!
And I thought at 57 I still knew everything......</end quote></div>
Doh!
#17
sac7000 that's the way the valves should sound , they're dead bang on spot that's the way every Honda i ever adjusted ; if you get them to tight they may sound quieter but the engine will run hotter and could burn a valve and i've seen it happen to many time's in the past 20 yrs that i was in small engine service and repair running my own shop till i retired in late 99' !..........
#18
I'm a new Rancher owner ( 08 TRX420FM ) and was wandering after the first break-in value adjustment at 20-25 hours, how often do the values need to be adjusted? Dealer told me 3-4 times a year. Is that accurate or is the dealer trying to drum up business?
Thanks in advance.
Thanks in advance.
Mojave250A
Jul 11, 2015 10:38 AM
